disable snmp trap l3vpn
disable snmp trap l3vpn {vr name}
Description
This command disables Layer 3 VPN MIB notification traps for the child VPN VRFs of the specified VR.
Syntax Description
vr-name Specifies the name of the parent VR where this RFC 4382 scalar is applied. If vr-name is not provided, then this command is applied to the VR in the current context.
Default
Disabled.
Usage Guidelines
None.
The following example disables SNMP traps for Layer 3 VPNs on the default VR:
disable snmp traps l3vpn vr vr-default
This command was first available in ExtremeXOS 12.6.0-BGP.
Platform Availability
